Author Topic: induction motor efficiency at reduced load  (Read 1558 times)
Offline NiHaoMikeTopic starter
    • Facebook Page
« on: October 02, 2013, 03:59:23 am »
If you take a 120V induction motor and load it with, say, 60% of its rated torque (assuming rated torque is its peak efficiency point), what voltage should it then be supplied with in order to get peak efficiency under that load condition? How much better efficiency can be expected as opposed to leaving it at 120V?
