I am searching for a connector for my DIY e-bike.
Ideally, the connector should handle:
- 18 low-voltage, low-current connections
- two 1A 120V connections
- three 120A, 120V connections
It should also be waterproof, durable, capable of a couple of thousand mating cycles, and easy to connect/disconnect.
Since finding an affordable product that meets all these criteria seems impossible, I would also be happy with something that works without the high-current phase connections.
The best I’ve found so far is a Snaplock D-sub
However, high mate cycle versions are difficult to find, rated for no more of 500 cycles and not waterproof
I would greatly appreciate your help and suggestions!
