Author Topic: Cheap SMB shorting dust-covers or dummy loads?  (Read 973 times)
Offline Pack34Topic starter
« on: February 03, 2017, 06:04:41 pm »
I'm using a small SMB connector for an interlock and wanted to source some cheap dust-covers or dummy loads for when the interlock is not needed.
I'm looking for more of a dust-cap like you see for BNC connectors. Those seem to be easy to find any only cost a couple dollars. Some of the dummy loads I've been able to find for SMB connectors are upwards of $20.
Does anyone know of a place to buy these cheaply? I just need to ground the signal.
