I found this voltage regulator.
Normally it will give +/- 15V but according to the datasheet it has a voltage adjust pin that can adjust both outputs between 9 and 20V.
In the circuit diagram the voltage adjust goes to the base of one of a pair of transistors.
The other transistor's base is linked to a zener diode going to ground and a resistor going to positive supply.
As far as I can see this pair will control the current mirror above it.
With the voltage adjust not connected the right transistor would always be off, right?
How do I use the voltage adjust? The datasheet doesn't specify this.
I can use it to turn the right transistor on before or alongside the left transistor but I cannot force the left transistor open or closed.
This puzzles me as the datasheet says I can adjust the voltage up and down.
Datasheet:
http://www.eoo-bv.nl/documentatie/SG1468T.pdfExtra question: How does this regulator compare to an LM78xx or LM317 and their negative counterparts?
Is it useful to make a small split rail powersupply?
