Author Topic: The X-Ray image thread by Aurora - various electronics via X-Ray imaging  (Read 116742 times)
Offline Mr.B
Re: The X-Ray image thread by Aurora - various electronics via X-Ray imaging
« Reply #50 on: September 07, 2015, 11:11:21 pm »
Really awesome stuff, thanks for sharing.
Offline FraserTopic starter
« Reply #51 on: September 07, 2015, 11:26:22 pm »
Some more mundane stuff ...... a 1N5401 diode
« Reply #52 on: September 07, 2015, 11:28:10 pm »
And a humble LED...
Yes I know you can see the insides visually on a clear one....but that's no fun is it  ;D
« Reply #53 on: September 08, 2015, 12:14:40 am »
Marvelous to think this thread is only a couple of days old and how many images already?   8)  :-+
 :clap:
« Reply #54 on: September 08, 2015, 12:23:45 am »
Thank you Tautech :)
The MX-20 takes about 30 minutes to warm up, calibrate and flat field the camera. Then it is very simple to make the X-Ray images. Almost as simple as using a digital camera.
The setting of the correct KVp and exposure time does need to be set up carefully, but once set at a particular KVp it does not need much attention.
The dynamic range of the sensor array is quite forgiving.
Aurora
Offline BravoV
  • +++ ATH1
« Reply #55 on: September 08, 2015, 12:53:51 am »
Thank you for sharing this.  :-+
Any chance of taking shot of modern/current Intel desktop cpu shots ?
Offline MrWizerd
« Reply #56 on: September 08, 2015, 02:15:57 am »
I hope you don't mind my saying that these could easily be offered I up as art, I do dabble in photography as one of my many hobbies and some of these shots would make excellent decor for a tech savvy art collector, heck I have seen black and white themed rooms that large prints of some of these would have fit well...  aside from that it is Defenantly interesting to see build quality before we break in, for instance some of the probes had stray wires, I don't know and doubt they would be a problem in most cases is still interesting to see the quality like that.
Edit: Would it be possible to get a transister, something typical like a L337?
Sent from my SPH-L710 using Tapatalk
« Last Edit: September 08, 2015, 02:31:34 am by MrWizerd »
Little beats big when little is smart, first with the head then with the heart ~P.K. Power of One
« Reply #57 on: September 08, 2015, 07:34:42 pm »
Had a few spares minutes so fired up the MX-20 again  :)
First a modern Laptop CPU....
Pretty boring really but I was asked to X-Ray one so here it is.
« Reply #58 on: September 08, 2015, 07:37:04 pm »
Now a transistor.... the MPSA14
You will see the bond wires but not much else. The silicon wafer/junction isn't visible when using the MX-20.
« Reply #59 on: September 08, 2015, 07:38:41 pm »
LM7805...
Again, sadly not much to see really.
« Reply #60 on: September 08, 2015, 07:42:00 pm »
A TDK 4GB Flash memory drive.
There is a lot going on in a small space so interpretation is difficult. X-Ray does not really help reverse engineer the schematic in such cases. It might show how to get into the case though  ;)
« Reply #61 on: September 08, 2015, 07:45:42 pm »
Here is an unusual DUT.... a Computar CCTV lens.
I use X-Ray to investigate the number and shape of the lens elements. When experimenting with unknown lenses this can be useful. I have used this method to identify and characterise Germanium thermal camera lenses that are too valuable to dismantle.
This method also identifies the various screw positions within the lens to aid disassembly.
« Reply #62 on: September 08, 2015, 07:46:43 pm »
Pens  ;D
Offline CrashO
« Reply #63 on: September 08, 2015, 08:07:39 pm »
Awesome thread. I was just lurking at all the pics but couldn't resist from asking you to keep them coming  :-+
Offline firewalker
  • Country: gr
« Reply #64 on: September 08, 2015, 08:23:37 pm »
The lenses contains PbO?
Alexander.
« Reply #65 on: September 08, 2015, 08:26:40 pm »
Glass is dense enough to stop a 35KVp generated X-Ray beam.
No idea if the lenses contain lead.
Aurora
Offline Ysjoelfir
« Reply #66 on: September 08, 2015, 08:28:06 pm »
The same goes for me! Those pictures are absolutely awesome, I love them!
Do you think it would be possible to look inside a vacuum tube? Guess the metal casing around the tube system wouldn't allow any view at all, even though it is quite thin?
Greetings, Kai \ Ysjoelfir
Offline MrWizerd
« Reply #67 on: September 08, 2015, 09:09:47 pm »
LM7805...
Sweet Thanks!  I was just curious what the inside looked like, I did not expect it to be ultra exciting, but it was informative. I recently watched a video on how the transistors were originally made/invented and was curious how that applied to modern transistors, and that answered the question.  Thanks again!
« Reply #68 on: September 08, 2015, 11:13:27 pm »
A few more images to end the day.
First of all Thermionic Valves (or Tubes for US readers)
The MX-20 cannot penetrate the metal parts but then I did not expect it to.
« Reply #69 on: September 08, 2015, 11:14:36 pm »
Professional GPS Antenna
« Reply #70 on: September 08, 2015, 11:16:04 pm »
AOR LA350 Ferrite Rod antenna. FET Pre-amp PCB is adjacent to output plug.
« Reply #71 on: September 08, 2015, 11:18:30 pm »
Adjustable foot from a Panasonic portable projector. Shows locking mechanism. I went for a close up to see more detail. I was not previously aware that the foot contained a steel rod foe strength.
« Reply #72 on: September 08, 2015, 11:19:50 pm »
Relay DPDT
« Reply #73 on: September 08, 2015, 11:21:01 pm »
HRC Fuse. Still looks serviceable  :)
Offline Melt-O-Tronic
  • Brilliant with a slaughtering iron in my hand!
« Reply #74 on: September 08, 2015, 11:25:01 pm »
I love this thread.   :-*
