@Ed.Kloonk - No, no borkage to date.
My X-Ray machines are relatively low power, low energy. I can't remember precisely the spec of the one I used for this image but it is something like 55kV, 0.5mA and exposures are limited to five or six seconds. I wouldn't put my hand inside (even if I decided to defeat the safety interlocks) but I've not seen any permanent damage to anything.
If I put a running video camera in the path of the 55kV beam then, as expected, there is a veritable snowstorm of noise.
A DSLR at high ISO in the lower power machine (microfocus tube, 35kV max, c 50µA) will also show a lot of noise, but I have no need to do that as the machine is equipped with a roughly 100mm square solid state imager.
I have yet to try putting anything close to the higher power tube aperture. I imagine that the (very much) higher intensity might give some semiconductors something to think about, but I don't know enough about the effects of X-Rays on silicon or germanium devices to make any meaningful guesses about what might happen. (The limited experience I have with bulk material seems to suggest silicon is largely transparent and germanium largely opaque, but there are relatively few germanium ICs available these days...)
Flash memory devices, which I'd intuitively expect to be more susceptible than, say, a power transistor, don't seem to show any problems after casual X-Raying.
Most of the memory card manufacturers warranty their cards as invulnerable to airport-type X-Ray machines, some of which use rather higher energies and powers than my little toys.
