To start off with, I'd like to point out that I am a
complete newbie when it comes to electronics (compared to an electrical engineer or hobbyist.) The most experience I have with electronics is that I have built and maintained a bare-bones PC, which more or less means that I have the ability to use a screwdriver and the skill to plug things in. I'm also relatively new to this forum, so I apologize in advance if I'm posting in the wrong sub-forum or in the wrong format. I've been watching the EEVBlog for about a year or two now out of sheer interest, but have never really done any projects on my own.
So recently I've stumbled into looking at
cassette tape designs and I immediately went into a hipster trance. Basically, I want to repurpose a cassette tape into an MP3 player that will essentially still work in a car tape deck. I've googled around looking to see if this sort of thing has been commercialized and found this
cheap, mass-produced looking thing. Instead of giving into this option, I would love to at the very least attempt to make something similar that is (hopefully) a tad more high-quality.
As I'm no expert on this matter, this 'project' will more or less just be me modding a cassette tape. I won't be creating circuit board schematics or basically doing this all from scratch. I figure the process will be extremely similar to
this guy's tutorial on similar subject matter.
Essentially what I plan on doing looks a little like this:
- Hollowing out a cassette tape (preferably one with some heft to it. One made of metal or a sturdy/high quality plastic maybe?)
- Buying a cassette-to-audio jack adapter and removing the magnetic head, attached PCB, and cable.
- Fitting the previously removed equipment into the new cassette tape.
- Buying a fairly small MP3 player (preferabley something that uses SDHC cards), gutting the circuit board & battery out of it and placing it in the new cassette tape so that the SDHC card port is near a wall of the cassette for easy access later on.
- Cutting holes in the side of the cassette so that the SDHC port, mp3 audio jack, mp3 charging port, buttons (play, next track, stop, etc), and the audio cable connected to the magnetic head can be outside of the cassette-case.
- Secure all of the circuit boards and other miscellaneous things down (Screws, glue, tape?)
- Finally screwing the cassette back together and pray that everything works.
I'm
most likely over-simplifying things, so please feel free to criticize me and show me how things should be done. This is all concept, so I have little to none of any of the materials. I've come here mostly for guidance for this childish endeavor I may partake in, so I appreciate all input and help. I'd particularly appreciate any suggestions for materials I could use such as small MP3 players I could use. If you want to remix this concept entirely, feel free to do so. My plan I listed earlier is most likely hasty and unintelligent, so any revisions are extremely appreciated. If this task evidently becomes to heavy for someone as inexperienced as I am, I will probably give in and buy the cheap, mass-produced version.
