Anodizing and Alodining have excellent heat transfer properties. Powder coating is a bit trickier. What you lose in heat transfer, you gain
by not having Al oxide as an insulator. In general, black powder coating is nett beneficial. The only "bad?" characteristic (in some cases) is that
there is a slight reduction in rate of thermal transfer, but the FINAL effectiveness is about the same. IF you need a fast transfer rate, just
upgrade your heatsink size / type a notch.
