Common mode chokes were introduced for CAN to handle the mismatch in timing on CANH and CANL due to difference between N and P channel transistors in the transceiver. As transceiver got better, but still maximum 1 Mbits/s, it was possible in some cases to remove the choke based on the EMC test results, but it also depends on different OEM's requirements. Some specify the CMC as a must, some as optional if it passes EMC without it. With higher bit rate, like CAN FD, the CMC might be needed depending on the application.
Termination has also changed over time. 10 years ago it was most common to leave it out and the OEM handled it on the vehicle harness. One German OEM had a specific requirement for a 120 ohm termination with an open end to be bridged in their harness if the unit was located at the end of the bus. A few years ago some OEM's started to ask for high impedance split termination with 2*1.3k.
Being able to handle the full supply voltage on CANH and CANL for more than 1 minute was also mandatory. This was also part of the miswiring test in ISO 16750-2 were all combinations were tested in a sequence. This test has implications on both transceiver selection (CM voltage range), TVS breakdown voltage and termination resistor power rating.
TVS diodes were not optional for the product I worked with as most transceiver handled up to 8 kV, but the OEM requirements were 15 kV for ESD.
One thing to look out for is connector pinout and how the CAN bus wires are located with respect to other wires with transients. On an older product our pinout on an internal harness was Vbat, CANH, CANL, 0V. During the ISO 7637-2 Pulse 1 immunity test (-600V, 50 ohm on Vbat) we got error frames on CAN. The product had a CMC and 120 ohm termination. Problem solved by twisting the internal harness to minimize the loop sizes and hence the mutual inductance coupling between the supply voltage pair and the CAN bus.
Also the wire insulation can have an impact as the harness impedance will change with material and thickness. Not sure how much it will affect immunity, but it will impact emissions.
