Hello All
Our shop has one of these Tek 492 SA's here at work that was long dead when I started this job two years ago. I'm trying to get it working again for our workshop and I have poured over this post here and there over the last few years when I had some free time. I followed the recommended parts replacements in the post by Gazucha last updated in Oct 2013 found here:
https://www.eevblog.com/forum/projects/tektronix-49xx-spectrum-analyzer-series-power-supply-failure/msg1269906/#msg1269906Our unit had a blown Q2061, diode CR2065, and mains-fuse along with some aged-looking capacitors. I ordered replacement 2SC4237 transistors from a trusted vendor and mounted them securely and isolated to the heatsink for the originals. I replaced all electrolytics except for the two large 750uF/200V units. I replaced the two small 47u/6v tantalum C5084 and C5085 caps. I have a bag of NOS 6A100 6-amp 1000V diodes and used one to replace the shorted CR2065 diode.
(07/28/17)
I reassembled and powered the full 492 SA on after double-checking everything I could think of. It ran for 3 or 4 minutes and seemed fine before blowing the mains fuse again. It blew the exact same parts as when I found it - Q2061, CR2065, and the mains fuse - no more and no less.
(07/31/17)
I finally ventured forth to power the supply on it's own and temporarily fusing the collector and the base of the replacement transistor for testing purposes - I hate the idea of replacing transistors like fuses if they keep blowing before I can get to anything to test for the remaining problem.
I wired in new Q2061 (2SC4237) and CR2065 (6A100) using the flying-wire method using #16-AWG solid pvc-jacketed wire salvaged from a new light-ballast replacement. I fused the collector with an AGC-8 fast-blow fuse and the base with an AGC-4 fast-blow fuse. I also fused the CR2065 diode with an AGC-5 fast-blow fuse. I replaced the 492's main AGC-4 fast-blow fuse. I powered on the power-supply module by itself disconnected from the main chassis. It is unloaded of course but has been running fine as long as I want to try. It tells me a little but not much that it runs by itself when unloaded.
(08/02/17)
I reattached the power supply to the main chassis to test operation with the three test fuses visible. I placed a piece of 2"-wide elecetrical tape folded over the Q2061 to protect against any accidental shorts. I powered up the unit and all started up and ran. I ran it for approx 3-5 minutes when I noticed that the 2" electrical tape started smoking and I then clicked off the power switch on my old B&K isolation transformer (personal home test-gear inventory). The Q2061 had almost went into thermal runaway, regardless of the small heatsink that I had attached to the 2SC4237. None of the test fuses blew and the transistor had not shorted or opened up - it's check on my old Fluke 79 diode check showed it was still good/viable. Since I didn't yet have an oscilloscope in our new shop, I had to wait and bring in my personal home-inventory old Tek 2245 oscope the next day for further in-depth testing.
08/04/17
I brought in my dusty and cigarette-smoke coated Tek 2245 scope today - 40 minutes with a microfiber cloth and a bit of Windex and looks 9 of 10 condition. Unfortunately only one of the two factory probes is 100%, so one lead it is for now, and hence the single-trace pictures. I again fired up the 492 PS by itself unloaded and it runs as long as I want it to, even with the heat-stressed 2SC4237 still on flying leads.
Once I re-familiarized myself with using my oscope (terrible I know), I finally started to get some insight into how terrible the signals hitting the Q2061 and Q2071 drive-transistors are.
- The oscillator output at TP6053 is spot on at 66kHz/15uS as-per the schematic, nice/crisp shoulders. Osc-adj pot fine and adjustable.
- The U6063B pins 12 and 13 outputs are nice/crisp and square also.
- TP6065 is a guess for me, that it's alright also as there is no current demand.
- U6069 outputs 1 and 13 look good to me, albeit, a bit of leading-edge ringing on each output - the waveforms look pretty-darn square otherwise.
- At the base of Q6077 after R6074-10k, something has went awry. What should normally be a low-transition in the squarewave is now a quick-exponential, almost full-voltage occurrence of approx 5.5Vac which likely equates to an almost dc-drive of Q6077.
- At the base of Q6078 after R6076-10k is a 9Vac 98% squarewave - some ringing on the leading edge, but just like the output of U6069 pin-13, a voltage-gain analogue.
- It seems that Q2061 is getting nearly twice the square-wave voltage drive of Q2071.
Thanks,
Dan G
