Hi madsci,
it was mentioned that there may be a prob on the output, so after first testing 'in circuit' I pulled one of the output transistors which then tested the same on the bench. All the others were then tested in circuit. Certainly no 'short' on any of the larger transistors.
So that you know ~ the other five LM318's all have very clean and solid soldering, whilst the two 16 pin LF13333N's on the board have quite weak and dirty solder connections. Perhaps one of these opened the circuit? The problem is that there are internal traces within the pcb, which without a schematic leaves me in entering the realm of guesswork.
Another member, Orange, mentioned that he normally just changed these boards but it would obviously be much better (here in Brazil) to fix it. It's just a bit of a ball-ache that the 492 is on the other side of Rio, which means a good 4-5 hours return travel just to test any repairs I may do.
One last thing before things get any more involved... Am I correct in assuming that this burnt Deflection Amp is what is causing the no-display symptoms?
Or is it not possible that something else, between the Defl Amp and CRT, caused this failure and therefore the blank CRT? Or could I have missed something in the PSU and that is where the failure is coming from? (this is the problem with no service manual)
Maybe it's time to join the Tekscopes yahoo group?
