So, I have been working on troubleshooting a buck regulator on a design of mine for weeks now. I am using a Texas Instruments LMQ61460 regulator on a custom board. I used the TI design tools to determine passive components and read the datasheet throughly. I designed my PCB and got to testing. The board worked!
The bad news is that the board did not work for long. The board would work no issues even up to 5A of load but at some point in testing, the board will fail. I even had two running for 150 hours straight (1 with constant 2.5A load, another with a toggling load). If the boards were in a constant state, they could run. If I put them on the power supply though, they would at some point fail when toggling power to the board via the power supply. When the baord fails, a short between the output and input of the regulator is formed.
Output of the SW node looks fine. I probed everywhere. I am worried that this is a transient issue but with only a 60MHz scope, there is only so much that I can see. I added some TVS diodes onto the board via a bodge and that did not work.
I contacted TI and asked them to look at the schematic. They said that they could not see any issues with it. Go figure.
I am increasingly thinking that this is a layout issue. I will attach screenshots of the layout. I am particularly worried about the ground paths around the regulator.
Any help or guidance will be appreciated!
