On my ranch, we do a lot of drip irrigation with water flow controlled by electric valves. In the past, we’ve used pilot-operated diaphragm valves … the type commonly used for lawn sprinklers. The problem has been that the irrigation water is high in particulates, mostly bits of plant material. Diaphragm valves have a small hole that is opened or closed by a solenoid for operation. This small hole is easily clogged by particulate matter interfering with operation. And yes, the water is filtered. Problem is the particulates can agglomerate once through the filter. In addition, some of the particulates are relatively long and stringy. So, by chance, some will go through the filter by having the narrow dimension enter a filter pore, but they lodge crosswise in the hole in the diaphragm valve.
The solution has been to use motorized ball valves as replacements, which we have been doing gradually. They’re more expensive but worth it. In the past few years, motorized ball valves have become available that operate electrically in the same way as pilot-operated diaphragm valves. Apply 24 VAC, they open; remove power and they close. Voltage spec is 9-24V AC/DC. Manufacturer did not supply current specs, so I measured them. Peak current flow at start of motor (in-rush lasts 1 second): 200 mA. Steady state current flow while motor is operating: 30 mA. Steady state current flow with power applied but motor not operating (i.e. open cycle completed): 9 mA (takes about a minute to decrease from 30 mA).
The ball valves have a drawback in that they cannot tolerate water intrusion into the electronics. The diaphragm valves are immune even to immersion … their electronics consist of one small solenoid that is completely sealed. This means that the ball valves cannot be installed in underground valve boxes that might flood … and flooding is always a risk. All our ball valves are above grade.
First ball valve was installed in 2019 and failed this year due to water intrusion. The valve was installed upright, above ground, but not in a cabinet. The valve supposedly has an IP65 rating, but water got in anyway. Pictures of a complete valve and the guts of the failed valve are below. The water rusted the motor. There are some faults in the case design. The motor sits in a pit at the lowest point in the case. Any entering water will go immediately to the motor. The case seal obviously failed. Further, the tongue and groove interface between the upper and lower halves of the case is the opposite of what it should have been. The tongue is on the rim of the upper half and the groove is on the lower half. With any failure of the seal, this arrangement promotes water ingress.
I tore-down the failed valve. The rusty motor is obvious. The valve has one circuit board with components on both sides. See pics. There are leads soldered to the board, and there are connectors that attach to the same CB traces as the leads. Presumably, the connectors are for testing. There are two leads for power input, two that go to the motor, and two pairs that go to limit switches. The side of the CB with the connectors will be called the top side.
On the top side, in addition to the connectors. there are 4 electrolytic capacitors. The 2 largest, are mounted horizontally, each rated 2.7 V 2F, and are wired in series. They are JH brand supercaps. Wiring in series doubles the voltage rating of the pair to 5.4 V but halves the capacitance to 1 F. Presumably these store power for closing the valve when power is removed. When 24 VAC power was applied to the input lines, the pair of supercaps charged to 5.6 V. The motor is 5 VDC. The other 2 electrolytics are 35 V 220 uF and 35 V 100 uF There is a tan disk component with label Q 72 XF050 on the disk and F1 on the CB. It’s a polyswitch resettable fuse rated 500 mA at 72V. There is a blue disk component with no label by a RU1 mark on the CB. It’s probably a MOV. There is an inductor (L1) with marking of 220; it gets hot when power is applied.
On the bottom side, there are two surface-mount ICs, each with 8 leads. One (U1) has markings of 34063 PNJZA, and is a 1.5-A, boost-buck-inverting switching regulator, 3-40 V input, 1.25-40 V output. These are made by many companies. The other IC (U2) has markings of RZ RZ7888 1846. It’s a Ruizhi 2-A DC, bidirectional motor driver. There is one small surface-mount transistor (N1). There are 3 large diodes (D1-3) and a full-wave rectifier (BG1). And there are a bunch of small, surface-mount resistors and capacitors.
When I applied 24 VAC to the power input of the failed valve, the voltage across the motor terminals was zero. If the motor was disconnected, the voltage on the motor leads was still zero. Presumably, there is a failure in the motor drive circuitry in addition to the motor itself. Resistance across the motor terminals was 10 ohms with the motor disconnected. Interestingly, when power was removed, the voltage on the motor leads jumped immediately from zero to 5.5 VDC and then began slowly decreasing. Presumably, the voltage is coming from the pair of super caps which were discharging internally or through a bleed resistor. So, it appears that the reversing circuitry was working OK.
When I applied 9 VDC to the motor terminals, there was a barely audible click with one polarity; silence with the other. The motor shaft could be turned easily by hand.
To prevent water damage in the future, all ball valves that are not in cabinets are covered with a small, transparent acrylic box.
Mike in California
