Author Topic: TDR function in Cisco routers.  (Read 718 times)
Offline SNTopic starter
« on: May 04, 2024, 05:50:45 pm »
Does anyone have intimate knowledge of the characteristic and timeline of pulses sent from the port of a Cisco router or switch during their built-in TDR test function?
I expect this is proprietary information and won't be outlined in any technical manual Cisco publishes.
It sounds like similar functions are now available from other manufacturer in recent years, so maybe there is more public knowledge available than what I've been able to find online.
Thanks in advance!
« Last Edit: May 04, 2024, 06:31:56 pm by SN »
Offline madires
  • A qualified hobbyist ;)
Re: TDR function in Cisco routers.
« Reply #1 on: May 04, 2024, 06:18:19 pm »
I don't think any vendor will publish signal details of their TDR function for Ethernet ports. But a DSO might give you an answer. ;)
« Reply #2 on: May 04, 2024, 06:31:00 pm »
Yes.  I certainly plan on getting a capture for myself at some point.  I am also wondering if other router manufacturers have basically standardized on a signal scheme for TDR functions or if they're all doing their own thing.  If I read it right, Cisco requires about 5 seconds per port to run the test.  I assume a great deal of that time is for processing/analysis.
« Last Edit: May 04, 2024, 06:36:00 pm by SN »
Offline alm
« Reply #3 on: May 04, 2024, 06:56:09 pm »
I've seen PC motherboards that also incorporate a TDR function. For example using this IC. There is some information here and here. TI also has an application note on TDR using Ethernet transceivers.
The following users thanked this post: madires
Online coppice
« Reply #4 on: May 04, 2024, 07:20:22 pm »
Isn't cable measurement a standard part of the echo cancelling function for gigabit ethernet and above?
« Reply #5 on: May 04, 2024, 07:38:24 pm »
That's exactly the kind of information I was looking for.  Marvel's documentation expresses this function as "Virtual Cable Tester" and it seems to be a registered trade name.  Thanks!
Offline madires
« Reply #6 on: May 04, 2024, 08:01:57 pm »
Each side sends training sequences to learn how the echo looks like, to determine what to expect as echo when sending data. If the echo is different then the other side is also sending data. The other's side data is the difference between the expected echo and the received echo.
« Reply #7 on: May 04, 2024, 08:44:11 pm »
Thanks to ALM for turning me to TI's site!
While browsing, I found a slightly newer Application Note for working with TI's built-in TDR function.
https://www.ti.com/lit/an/snla330/snla330.pdf?ts=1714855065817&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FDP83825I
