Hey!
I have my PCB designed and prototyped and I'd like to put in an order with Seeed Fusion Premium but I wasn't sure what size my tabs should be. I'd like to do something similar to how this PCB is laid out, so I can just use a pair of side cutters to depanelize.
![](http://i.imgur.com/mj2ywGs.jpg)
Here is a closeup screenshot of the tabs on my panel along with some info
![](http://i.imgur.com/r1AbOUe.jpg)
24x30mm boards (100mm x 100mm panels)
0.8mm thick pcb (half standard)
4 corner tabs
2.4mm diameter routing bit
0.2mm grid in Eagle
The board doesn't contain any components and won't go through a pick and place machine, it's an adapter board.
Anyone know what size i should make my corner tabs?
Thanks!
-Ben
