Author Topic: High performance DIY hotplate/stirrer [project log]  (Read 2378 times)
Offline AlexTopic starter
« on: October 30, 2013, 10:09:31 pm »
Recently I was given a number of cartridge heaters and was thinking of a project to put, at least a few of them, in good use. The etch tank idea on that thread would be better off with a low power, low power density immersible heater.
What I have decided to use them for is as the heating elements of a hotplate/stirrer combo.
Despite the classic chemistry lab applications, I know many use such hotplates to reflow SMT components. So I will keep a high level, mostly pictorial log of key stages in this project to chat over.
Firstly to lay down a few requirements. I expect these to get 'massaged' during development.
Must have:
  • Heating area: 300x300 mm
  • Max temperature unloaded: 450-500 degC
  • Max temperature non-uniformity: 10 degC
  • Temperature control method: PID
  • Stirring speed: 100-2500 RPM (TBC)
  • Stirring capacity: >= 10L water
  • Single power outlet: 3kW (13A 240VAC)
Would like to have:
  • Coated surface for chemical splash resistance
  • Hot surface indicator - Active when the surface is too hot to touch
  • Secondary immersible process temperature sensor
Design drivers:
  • Low profile
  • Split construction - plate and controller are separate
  • Robustness
  • Electrical safety
Flexible on:
  • Weight
  • Cost
  • Time
  • Heat up/cool down duration
Already available components
  • 11x Watlow tubular cartridge heaters: 750W 240VAC each. Ceramic bead termination insulation and fibregalss wiring insulation
  • 1x K type thermocouple panel connector
  • 1x 10A and 1x 25A Celduc SSRs
The bar is quite high - there is a lot of work to be done and stuff to be purchased! So stay tuned for the next update where I plan to look at what is available and other peoples' hotplate design.
Alex.
