Author Topic: Symbol for MOSFET  (Read 23649 times)
Offline MedoTopic starter
Symbol for MOSFET
« on: December 18, 2010, 06:51:44 pm »
Like everybody I give my components some generic designator. All diodes start with D (e.g. D1, D2...), all capacitors start with C, all transistors start with Q and so on...
I have issue with MOSFETs. Which designator should I use for it?
Usually I just call it MOSFET1 but I am wondering whether there is some standardized one-or-two-letter symbol for it...
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Symbol for MOSFET
« Reply #1 on: December 18, 2010, 06:59:24 pm »
normally "Q" is used
« Reply #2 on: December 18, 2010, 08:27:40 pm »
I usually use Q for transistors. I feel uneasy using it for MOSFETs.
Alex
  • Guest
« Reply #3 on: December 18, 2010, 08:57:49 pm »
Electronics in a very well regulated industry, you should be surprised if there is not a standard for something widely used.
Component 'classes' (eg. C, D, R, L etc) for schematic diagrams are covered by IEEE 315A and IEEE 315A (section 22).
http://standards.ieee.org/findstds/standard/315-1975.html
http://www.docstoc.com/docs/17118743/IEEE-315--1993-_Graphic-Symbols-for-Electrical-and-Electronics-Diagrams_
(page 217 in the second link)
Q is used for transistors (amongst other things).
A MOSEFT is a transistor too, for some reason we associate BJTs with the term though.
If someone knows where standards (IPC, IEEE, IEC) can be downloaded, please let us know! :-)
Offline cyberfish
« Reply #4 on: December 18, 2010, 09:02:35 pm »
metal-oxide semiconductor field-effect TRANSISTORS
Offline MrPlacid
  • Hobby Hobbyist
« Reply #5 on: December 18, 2010, 09:11:47 pm »
QM works for me.
Offline allanw
    • Electronoblog
« Reply #6 on: December 18, 2010, 09:23:06 pm »
Some people use M's.
Alex
  • Guest
« Reply #7 on: December 18, 2010, 09:33:43 pm »
Non-standard.
QM works for me.
Which schematic editor do you use?
Offline MrPlacid
  • Hobby Hobbyist
« Reply #8 on: December 18, 2010, 09:55:04 pm »
MSPaint + infraview(for flipping, rotating), everything else is too complex for me ??? One day, I swear I'll learn to use a real one.
« Last Edit: December 18, 2010, 09:59:37 pm by MrPlacid »
Alex
  • Guest
« Reply #9 on: December 18, 2010, 10:20:51 pm »
If you can do a schematic in MSPaint you will find a proper schematic editor much easier!
I was asking because EAGLE does not have a facility to add a subscript designator on the class letter. So you can have QM but not QM.
Not sure how this is handled in say Altium Designer, if at all.
« Reply #10 on: December 18, 2010, 11:44:57 pm »
Q it is. :)
Thanks to everybody.
Offline MrPlacid
  • Hobby Hobbyist
« Reply #11 on: December 18, 2010, 11:51:39 pm »
I don't have much knowledge in those editor, but don't they allow you to add labels? If they do, can't you drag an "M" and place it slightly lower than the "Q" to get QM?
Alex
  • Guest
« Reply #12 on: December 19, 2010, 12:40:15 am »
You can specify a class designator eg Q when making the library and then every time you place a component a number increments that is added to the class designator. But all of this is using the same character size and you cannot split the two. You can manually add an 'M' if you treat it as a text comment but that just takes too much work. You can see that its a mosfet from the actual schematic.
Online Zero999
  • 0999
« Reply #13 on: December 19, 2010, 09:35:50 pm »
LTSpice uses M for MOSFETs which is probably not right but I don't bother changing it.
Offline Scutarius
« Reply #14 on: October 28, 2013, 02:23:44 am »
Does anybody has a copy of the  IEEE 315A?
Offline skipjackrc4
« Reply #15 on: October 28, 2013, 02:33:05 am »
MOSFET's are transistors, so...
Offline Kremmen
« Reply #16 on: October 28, 2013, 09:08:12 am »
I have the IEEE 315-1993 "Graphic symbols for Electrical and Electronic Diagrams (Including Reference Designation Letters)". No A suffix in the doc though.
It has a comparison list documenting the differences between ANSI/IEEE and IEC component lettering and transistor is Q for ANSI/IEEE and V for IEC and i have seen both in diagrams. Definitely neither separated a FET from a BJT on that level. It is obvious from the main text detailing graphic elements for FETs and BJTs that they are considered variations of one component - the transistor.
So do like the pros do - use Q for both (or V if IEC floats your boat).
M is reserved for many kinds of devices, none of which are even close to anything like a transistor.
Nothing sings like a kilovolt.
Dr W. Bishop
Offline codeboy2k
« Reply #17 on: October 28, 2013, 11:23:23 pm »
Some of the older schematics you come across use TR for BJTs  , i.e. TR1, TR2, etc... mostly TR101, TR102 though... like that, and M for MOSFETS...
I never liked it.  I always use Q.   to me, a BJT, UJT, FET, MOSFET, or IGBT is always a Q...
however, SCR, TRIACS, DIACS, SCS, GTO, ETO, IGCT, BCT, LTT, MCT, yadda, yadda, yadda.... everyone is confused on how to label those.
Offline armandas
  • Country: jp
    • My projects
« Reply #18 on: October 29, 2013, 08:22:23 am »
Here's a useful table from Tom Hausherr's blog.
Offline Kremmen
« Reply #19 on: October 29, 2013, 09:50:13 am »
Well, with no disrespect to Hausherr & al, not everyone is confused as to the lettering of components. There is little benefit in specifying the component too minutely using the ID symbol and for that  reason the standards use component classes, not individual component types in the designations. Thus all of the 3 and 4 letter comps in you post are simply Q or V, depending on whose list you prefer to use; ANSI/IEEE or IEC.
For reference, here is the comparison, attached as a PDF.
Dr W. Bishop
Offline codeboy2k
« Reply #20 on: October 29, 2013, 11:01:19 am »
...not everyone is confused as to the lettering of components. [...] all of the 3 and 4 letter comps in you post are simply Q or V, depending on whose list you prefer to use; ANSI/IEEE or IEC.
Thanks for the reference. Yes, Q or V. But if you look back at most publications from the 60's and 70's and 80s and even some more recent schematics, you'll find that those types of thyristors are labeled simply as they are.  SCS1, SCR1, DIAC1, MCT1, etc.. that's what I meant by everyone is confused.
Perhaps they are over it now, and it's not as bad as it once was.  And, thanks to your reference, even I know to call them all a 'Q' :)
Offline c4757p
  • adieu
« Reply #21 on: October 29, 2013, 11:16:37 am »
To what extent do those standards even get used? I'm pretty sure the only time I've seen a dedicated letter for "amplifier" was in LTC datasheets... otherwise they're just the usual U. E is specified by both for "miscellaneous", but that's almost universally U, unless I misunderstand what "miscellaneous" is. I don't recall ever seeing X for a socket (both agree on that), either A or BT for a transducer, or a dedicated designator for an isolator (interestingly, ANSI uses the same as for a termination - AT).
Offline Kremmen
« Reply #22 on: October 29, 2013, 01:24:51 pm »
I read your post carelessly :) Yes they used to just come up with a designation that appeared to make sense according to some logic. No prob, but one should make an effort to use standards if such exist and there is no penalty in doing so. But i am sure we agree on that point :)
Dr W. Bishop
Offline Kremmen
« Reply #23 on: October 29, 2013, 01:34:06 pm »
They are certainly not mandatory - at least i think they aren't though i can't recall what EU Directives might say about it. But since you are not guaranteed to have a symbol for every conceivable gizmo, some leeway is needed. Standards are of course just someone's idea how things could be done in a uniform or "good" way, not a physical law or something. So you are free to ignore standards unless some outside agent (such as Customer or an Approvals body) makes demands.
At least for me the designator X is commonplace. In European (well, Nordic) schematics X is universally used to designate a pluggable connector of some kind, and i always mark terminal blocks using X.
Dr W. Bishop
Offline c4757p
  • adieu
« Reply #24 on: October 29, 2013, 02:13:31 pm »
X is common here for crystals. It's a somewhat common American abbreviation style to replace a syllable containing K and S sounds - CryStal - with an X. (In the math and CS world, I've even seen "fxn" for "funCTion".) I haven't seen it for connectors, though. I've seen J and K, and the occasional misused P (should be for a Plug).
Personally I'd prefer to use a simpler system. There's no reason everything needs to have its own narrow little category. I use:
BT    Battery
C     Capacitor
CV    Capacitor - variable
D     Diode (forward)
DS    Display/indicator
DZ    Diode (Zener)
F     Fuse
J     Jack / female connector
JP    Jumper (configuration jumper, not jumper wire)
K     Relay
L     Inductor
P     Plug
Q     Transistor/other discrete semiconductor
R     Resistor
RT    Resistor - thermistor
RV    Resistor - variable
SW    Switch
T     Transformer
TP    Test point
U     Integrated circuit
V     Valve/tube
May have missed a couple. I make subcategories in cases where a component is significantly different in operation or use (Zener diode, variable passives, etc) but otherwise don't need a million different names. Anything that fits into multiple categories takes the more descriptive (a Neon lamp or VFD is DS, not V, for instance, just like an LED is DS rather than D). For more obscure things, I figure using an "official" single/double-letter designator is more likely to cause confusion when people aren't familiar with it. I can just use something like "SP" for speaker, "MIC" for microphone, "ANT" for antenna, etc.
« Last Edit: October 29, 2013, 02:27:39 pm by c4757p »
