Author Topic: SIL pad connected to GND.  (Read 996 times)
Offline boyddoteeTopic starter
« on: December 15, 2023, 11:09:52 am »
Hi All,
Hoping someone may be able to answer why, I'm currently working for a company that specialises in rail and road lighting. This particular device is a power supply for a HID headlamp.
The question is why would the engineer that designed the board specify electrically connecting the SIL pad to ground when the SIL is not conductive (I've checked).
In advance, I cannot unfortunately share the schematic for IP reasons.
Thank in advance for any ideas.
Chris.
Re: SIL pad connected to GND.
« Reply #1 on: December 15, 2023, 11:17:04 am »
Photo attached.
Online Phoenix
« Reply #2 on: December 15, 2023, 11:31:55 am »
The pcb has scrn which could mean screen. Sometimes an electrically conductive screen is placed between a switching device and the heat sink. This is used to guide capacitively coupled currents to a friendly node instead of say earth where it can radiate out.
In this specific scenario I can't see any screen unless it's built into the silpad.
« Reply #3 on: December 15, 2023, 11:46:57 am »
Thanks Phoenix, the SIL pad in none conductive in this case which is why its puzzling.
The SCRN although not easily visible could also refer to a guard trace that's under there, and ultimately runs along the transformers pins which on that side have no connection.
« Reply #4 on: December 15, 2023, 12:00:49 pm »
Other side, I think with the distance there would be little to no coupling effect.
The heatsink itself is not connected to GND.
Offline Sacodepatatas
« Reply #5 on: December 15, 2023, 12:17:38 pm »
It is puzzling deliberately. It's an authenticity check. Do you know the issue that had Van Halen music band with brown colored M&Ms? That's the same sort of thing.
Think of It: If you find a copycat device trying to pass as genuine, but they don't include such special feature because looks silly, that's an evidence of counterfeit. If a design from another brand is so suspiciously similar that also includes such a feature just because, then the original designer can alledge that their IP was stolen.
It's like a watermark.
« Last Edit: December 15, 2023, 12:39:53 pm by Sacodepatatas »
Offline Conrad Hoffman
    • The Messy Basement
« Reply #6 on: December 15, 2023, 09:45:22 pm »
Another possibility is that it ensures some other aspect of the assembly is done correctly or it provides some mechanical protection. Think outside the electronic function.
Offline sleemanj
  • Professional tightwad.
« Reply #7 on: December 15, 2023, 09:53:06 pm »
Or it silences an unconnected component/pin error in the Schematic/PCB editor.
« Last Edit: December 15, 2023, 09:55:16 pm by sleemanj »
