Hi, I finally got the latest version of my PCB and soldered just a few necessary components (I forgot which ones...) and the board was working great! So I finish the board and connect it up, and all of a sudden, no target found, my STLink (Those cheap crappy ones) also blinks red when I plug it in. Thinking I fried the MCU with heat, I swapped it to a blue pill and it works perfectly there, so it's a configuration issue I assume...
I checked the traces and they conducted to the pins on the MCU. I can't figure this out. I reviewed the datasheet again to see if I did something wrong with one of the pins (Like the wake pin or boot1) but it seems like my configuration is OK?
Any ideas about what could be happening? I've been trying to get it to work for the past 2-3 days.. this happened again on a second board. This project was supposed to be a quick and cheap DIY solution but it's been taking more than a month so far xD
