I dont know what type of transistor should I use.Mesfet,Jfet,galium nitride HEMT,HBT.... there is so many transistor types and I have no idea why I should use one over another.
It will be used as OFF/ON switch only,no linearity or biasing needed.I need low noise.Voltage emitter > collector is 10 to 20 V,curret will be 100 miliampere RMS,but probably alot higher peak currents for very short duration.Switching frequency will be 3MHz but I would like if rise and fall times are less than 10% of the pulse square,generaly the faster the better but I dont need microwave capability.High gain is nice but I dont need it.
Size,weight,and price doesnt matter.
