AFAIK, oven type magnetrons use thoriated tungstent filaments.
In that case they should work indefinately*
That's the method normally used to control beam current in x-ray tubes and depending on how constant a current is needed may actually be suitable for the OP's requirements.
Still I get the impression his boss may not like it.
*well, for their normal service life.
