I read that I need to do set font command but in this case I only need one custom font. So I converted my ttf file to bdf which is supported by u8g2. The thing is that I wanted to add the setfont command on the beginning and rest of the place should be the scalling of the font and don't want to use separate font files for different sizes. I meant that, the smaller font is 8px which is default and othe size should be multiples of 8 which double the size (double the pixel size) . Any ideas? Thanks
