I'm a big fan of the AGM batteries, particularly in underseat installations where acid leakage can go undetected much longer and rust out the car.
Things to check:
- Will it fit? It looks like the 74Ah lead-acid is smaller than the stock AGM battery. That's usually OK, as long as whatever holds the battery in the car can still work.
- Are the terminals the same type (side vs top post)?
- Are the terminals on the same side as original? (some batteries have positive and negative on the "other" side from each other)
Electrically, it'll be "mostly fine". AGM and lead-acid batteries chemistry is slightly different and the charging targets are different. It's possible that the car is targeting the charge profile for AGM which will slightly overcharge the lead-acid, leading to a lower battery life and higher likelihood of leakage. For a 7-year old car, you have to decide if that's worth it or not. (I'm generally one to keep cars 15-20 years, so 7 year old car isn't getting into the "clunker; who cares?" territory for me.)
I'd replace with another AGM, but I realize that's not financially equal decision.
The lead acid substitute will "work".
