Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Stacked board
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Stacked board (Read 894 times)
waulu13
Newbie
Country:
Stacked board
on:
December 21, 2018, 11:21:07 am »
I am designing a stacked board, something like this,
https://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&uact=8&ved=2ahUKEwjP39yW5bDfAhVMThoKHVlvCIkQjRx6BAgBEAU&url=https%3A%2F%2Fwww.datasoft.com%2Fproducts%2Fsidebridgesom%2Findex.html&psig=AOvVaw3Cl1MTiHHdDLgm_G3Rat1e&ust=1545477148962050
The top board has these connectors,
https://www.hirose.com/product/en/products/DF40/DF40C-80DS-0.4V%2851%29/
and
https://www.hirose.com/product/en/products/DF40/DF40C-50DS-0.4V%2851%29/
and I would to place components between the boards but there’s not enough height for that. Can someone recommend solutions please? I thought about designing an adapter just to create height. Maybe and adapter and cables to place it somewhere else. Maybe I can put a small pcb under the connectors to create height. what do you think?
Thanks in advance
Logged
Cloud
Regular Contributor
Country:
Re: Stacked board
Reply #1 on:
December 21, 2018, 11:49:08 am »
I thing the easiest solution would be to use higher connectors if this is possibility
Logged
Rerouter
Super Contributor
Country:
Question Everything... Except This Statement
Re: Stacked board
Reply #2 on:
December 21, 2018, 12:05:24 pm »
Hirose do make taller stacked connectors, not to sure on what the series is called but I have found them in VDO gauges, about 22mm board to board when mated.
Logged
waulu13
Newbie
Country:
Re: Stacked board
Reply #3 on:
December 21, 2018, 12:58:21 pm »
Thank you for the quick reply.
I found these connectors
https://www.hirose.com/product/en/products/DF40/DF40HB%284.0%29%2D50DS%2D0.4V%2851%29/
and
https://www.hirose.com/product/en/products/DF40/DF40HC%284.0%29%2D50DS%2D0.4V%2851%29/
4 mm height is enough for me. Now the problem is that I don't know if I can connect a male with 1.5 mm height
https://www.hirose.com/product/en/products/DF40/DF40C%2D50DP%2D0.4V%2851%29/
with one of that female connectors.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Stacked board
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
