Off-topic questions:
Is it good circuit? Can I achieve better performance (input impedance, noise, bandwidth) with different components, circuit or just with a single opamp?
Maybe it would be possible to get similar results by placing JFET source followers in front of a fast and low noise bipolar opamp such as AD797. Some commercial JFET input opamps were actually made that way. I suppose it will be stable as long as the FETs are able to drive the inputs of the chip without excessive phase delay up to tens of MHz.
Another straightforward technique is to parallel and average the outputs of several JFET opamps of sufficient speed in order to decrease noise. IIRC, JFET opamps with noise near 3~4nV/rtHz are readily available so it would take just a few of them.
Note that whatever technique you use to make a unity gain stable amplifier with 20MHz unity gain bandwidth, its closed loop bandwidth will fall to (typically) 400kHz at gain 50x.
The only way out is to employ some current feedback technique, as is common in single chip instrumentation amplifiers for example.
I see 2 ways to add compensation for lower gain:
1) add a R C series element across the OP-amps inputs. This reduces the input stage gain at the high frequencies and keeps the high gain at low frequencies.
This results in a conditionally stable amplifier, i.e. unstable at certain closed loop gains. For stability up to 50x gain, JFET input stage gain must be flat at unity starting from the aforementioned 400kHz (likely somewhat lower in practice). So the resistor should be equal to input stage transconductance (maybe a little lower) and the capacitor must be sized to give appropriate time constant.
2) Add capacitors and maybe series resistors around the OP amp to make it a differential integrator. So OP-amp output to inverting input and non inverting input to ground (or maybe the possible supply).
This is the usual solution in vintage three stage opamps like NE5532 or OP07. It can achieve reasonably flat 20dB/decade open loop gain rolloff and stability at all gains from unity up. There are two singnal paths through X1: integration of input stage current appearing at X1:IN- and direct voltage follower action at X1:IN+. The latter must be suppressed at high frequencies by AC grounding IN+ as mentioned by Kleinstein, otherwise the composite amplifier will never be stable at gains lower than the gain of the input stage alone.
