I've used this guy:
https://www.alibaba.com/product-detail/universal-3km-433-cheap-rf-module_1809987082.html?spm=a2700.7724838.0.0.r8Q13YFor RX, i used:
https://www.alibaba.com/product-detail/315-433MHZ-RF-ASK-Receiver-Transmitter_2005979852.htmlIt's a little over powered for 1km, but, dirt cheap and functional (I tried it...) with most of the cheap 2-3$ superhert receivers.
In the city, it should give you 1km, outside of the city, about 2.5km.
Going through the concrete walls of my house + through 15 other houses + some help from reflections, you will get around 0.5km. See attached photo. The white ring is 0.5km.
Remember, there is a lot of traffic on the 433 Mhz band since it is use by so many gadgets. You need good MCU code to drive it and decode on the other side to deal with all that random interference in the city, but it is very doable since you got that 3watt burst during transmit.
2 notes, your transmit data pulses shouldn't exceed 50% duty cycle, or it will overheat. The data in will work with a full clean 3.3v, preferably 5 v signal. The power supply needs 12v. It comes with a tuned antenna. I recommend modulating your transmit data with a carrier like an IR remote control signal so your receiver on the other side can use your carrier frequency to demodulate the data differentiating it from surrounding noise and interference,..
All those red arrows are the houses the signal had to go thru to reach my receive location. Out in a flat open area, or, having the transmitter high up, you should get at least double the distance I got in my suburb test. I was transmitting a 4Khz test carrier through the transmitter & testing the receiver at the other end.
I requested a quote for 5 from this guy: (Even though he says 200pcs minimum, he still sold me 5, + 5 receivers)
TX
https://www.alibaba.com/product-detail/universal-3km-433-cheap-rf-module_1809987082.html?spm=a2700.7724838.0.0.r8Q13YRX
https://www.alibaba.com/product-detail/315-433MHZ-RF-ASK-Receiver-Transmitter_2005979852.html?spm=a2700.details.maylikever.10.697a8c3epkWsf4
