I'll give this a shot. Thank you for the suggestion. What is the thought process behind this circuit. Why is it better?
On an ideal part with rail to rail swings, and symmetric trigger points (1/3 and 2/3), R2 alone will give 50% duty cycle.
A real (non CMOS) part does not quite manage rail to rail, so the added R1, skews the default 'almost 50%' to be closer to 50%.
When I posted this I was more concerned about the overshoot that can be seen in the attached pictures than I was about getting a 50-50 square wave.
You could also try pullups and pull down loads.
The original 555 has a multiple transistor output drive, which unlike CMOS does not pull cleanly to VCC. This will not give a 'clean' rail to rail square wave.
If you have any CMOS logic, you could try adding a non inverting buffer, and scope that.
