I wanted to have a look at other people's opinions on something.
Suppose that a 3.3V signal from a microcontroller is used to switch a high-current load via a low-side N-channel power FET.
What's the most economical choice of gate driver IC or circuit to interface between the microcontroller and the gate of the power FET, to provide an appropriately high Vgs to turn it on hard? We will assume that the load operates at 24V, the microcontroller operates at 3.3V and there is a little bit of current available from a spare 10V rail which is probably suitable for the gate driver.
What's the most economical way to implement something that will work reliably?
Is a dedicated, relatively expensive gate-driver silicon justified, or would something simple such as the attached image, using a common jellybean cheap 2N7002, work effectively?
Or is it a simpler, more reliable, or overall cheaper option to choose a logic-level MOSFET with an appropriately small gate threshold to accept a direct drive from the microcontroller? Obviously this will decrease the available choice of devices and may increase cost a little.
