I'm designing the output stage for my 10MHz GPSDO. So far I've narrowed down the sine wave output op amps to either AD8052 or LM7171 (mostly because I have some of both).
On some designs I've seen on the 'net, the output is transformer coupled for 'isolation' (that's all that was said about it). I have some Minicircuits transformers that would suit (T1-1T-KK81+), but I don't really understand what the benefits and drawbacks are. Other than DC isolation of course, with the drawback that I then have to somehow insulate the output sockets from the (grounded) metal panel of my enclosure. Is there anything else I should know? Is it really useful? I'll be using the GPSDO as a reference to the usual suspects in my home lab.
Also, where would I put ESD protection (CM1213A I think)... on the primary or secondary side?
