You don't have to read much about the history of analog circuits before you come to George A. Philbrick Researches Inc. Philbrick employed some of the industry's greats like Bob Pease, Robert Dobkin and Jim Williams amongst other.
I have collected a few of the historical parts, that I would like to share with the group.
1965 SP2AFrom around 1965 I have a Philbrick SP2A. This was built in a nickel-plated steel box. The box is fitted with a 15 pin edge connector. I have the matching socket. I believe the one that I have has never been used.
This op-amp made with silicon transistor was designed by George Philbrick, based on the Bob Malter P2 Design. The SP2A was fitted into a package designed by Walter Kern. With Bob Pease doing the layout.
These were not cheap. The price was $227.00 in 1965, that is about $1725.00 in today's money.
Analog computing was big business. This was equivalent to high end microprocessor.
More information can be found here:
http://www.philbrickarchive.org/news%20from%20philbrick;%20new%20philbrick%20plant%20in%20dedham,%20massachusetts.pdf1968 Philbrick 1011 I have a few Philbrick Nexus 1011 Amplifier. These samples range from 1971 to 1977. Unfortunately, none of them work. You can see the socket. The pin pitch is 0.2 inches.
Here is a link to the 1011 datasheet:
http://www.philbrickarchive.org/1011.htmThis was $42.00 Qty 1 in 1972.
The specifications can be found here, on page 12:
http://www.philbrickarchive.org/1972%20product%20guide.pdfRegards,
Jay_Diddy_B
