Modern times require modern solutions. Do you feel angry because your brand new Tektronix scope has fucking readout rings and the only probe that you have is the switchable Rigol probe? Do you hate Tektronix because they didn't add a selectable probe multiplicator switch thinking that you'll spend 300 euros for a single probe while you are at university without any money income except for Christmas gifts?
Well, Giovanni is here for you.
Giovanni costs 20 cents. and it's made with a pipe filler (1 cm internal diameter, 1.8mm thickness) and a 10k resistor bent to reach the back and the internal circle of the filler. Giovanni lets you read the right values from your scope without any internal hack or goofy springs. Forget to use your brain to do a simple 10x multiplication. The rubber prevents scratches on the readout rings, providing insulation with the BNC connector and a natural spring action while the resistor wires do the trick. A new level of fitness lets to insert Giovanni between your scope and any probe in the universe
. Don't let Tektronix ruin your day, use Giovanni. Tests (?!?!?!) with a Tektronix p6112 fixed 10x
and with a switchable Rigol pvp3150
The future is here.
