Author Topic: Easy charging of 2 cell lipo?  (Read 4494 times)
Offline smackaayTopic starter
    • Steve's Junk
« on: April 25, 2013, 08:14:55 pm »
I have a project that I'm working on and even though the project is finished the customer wants a charging port instead removing the batteries and charging them externally. I'm running 2 18650 lithium ion batteries and while I see lots of solutions for a single cell, I don't see much in the way for 2 cell charging. I was thinking that I could try using two single cell charging IC's but I have no idea how they're going to behave if I split the ground between the batteries, has anyone done this?
I've never used charging IC's so I have no idea what to expect. Any help would be greatly appreciated. :)
Come see my boring site - http://smackaay.com/
Offline richcj10
Re: Easy charging of 2 cell lipo?
« Reply #1 on: April 25, 2013, 08:23:07 pm »
Works really well:
http://www.digikey.com/product-detail/en/MCP73213-A6SI%2FMF/MCP73213-A6SI%2FMF-ND/2125537
I don't remember what cells I actually used this on but they where LG 26650 Li-Ion's and it did a good job.
I would make sure your cells are at the same voltage prior to installing into product. The cells should stay nicely balanced.
    • Steve's Junk
« Reply #2 on: April 25, 2013, 08:48:16 pm »
Wow, that's perfect, thanks! :)
Offline Donziboy2
« Reply #3 on: April 30, 2013, 10:49:34 am »
I dont see any balancing on that IC at all?
Offline richcj10
« Reply #4 on: May 02, 2013, 08:22:59 am »
Your right, there is none. hence:
The cells when discharged at a low rate would require no balancing.
vlf3
  • Guest
« Reply #5 on: May 02, 2013, 09:43:32 pm »
Lipo lithium ion batteries, are they that safe ! from what I have seen; or is the media hype causing concern.  :o
Offline richcj10
« Reply #6 on: May 03, 2013, 12:27:32 am »
It depends on how you use it. If you use it in a combat bot, then yes, you will need to balance. The current draw is so great that you need to make sure the cells are at the same potential or boom. I did how ever make a 24v pack with A123 cells and never balanced them and they where fine in a 120lb combat. If you have the cells close to each other and will not be pulling less then let's say 500mA then I can't say that it would be a problem. I know someone from NASA that knows about battery's and I will talk to him.
