Author Topic: Single rail opamp fundamental flaw?  (Read 4929 times)
Offline BiOzZTopic starter
« on: April 18, 2013, 02:51:16 am »
me and a friend of mine were working on a power supply together for a future project (that i must make a post about here) and he said we need a -1V rail to make the op amps give accuracy (vcc is 12v)
i dont know much about opamps but im quite sure most single rail opamps work fine from VCC to 0V with a single rail input but he says the resitence in the totem pole wont let the output hit zero ... i said that resistance would be to small to be noticeable than he pointed out the voltage drop in the feedback ... claiming this is a fundamental flaw in single rail opamps
so my question is do you need a negative voltage to negate the (if any) positive voltage offset in a single rail opamp?
in this project i humored him and chose a copper amp with the uneducated claim that there designed for this ... ill look up my facts later  O0
PS: the power supply were making has many positive and negative rails so adding in a negative rail wont be too difficult with a redesign but for future reference id like to know
My one regret in life is learning to speak English on the internet ...
Offline c4757p
  • adieu
Re: Single rail opamp fundamental flaw?
« Reply #1 on: April 18, 2013, 02:56:17 am »
He's right, many "single-rail" op amps won't quite hit the negative rail, at least under certain load conditions. You shouldn't have to bias it down like that for a simple power supply, though (well, depending on which op amp it is).
Offline BravoV
  • +++ ATH1
« Reply #2 on: April 18, 2013, 02:56:51 am »
How much current the opamp was sinking ? You might need lower negative rail if its too much.
Consult the opamp's datasheet on the sinking capability.
« Reply #3 on: April 18, 2013, 03:01:40 am »
how much will it generally offset from the negative rail? i know its probably in datasheets but were using general component symbols at this time
Offline c4757p
  • adieu
« Reply #4 on: April 18, 2013, 03:04:36 am »
Pick an op amp before you continue. There are vast differences between models. For a simple power supply, if you don't require high precision, I recommend the common LM324. Look under "Application Hints" for information about use near ground.
Offline BravoV
  • +++ ATH1
« Reply #5 on: April 18, 2013, 03:17:13 am »
Every op-amp's datasheet has the row called "Output Voltage Swing" and it depends on the load.
Even its called single rail op-amp, it doesn't mean the op-amp capable of maintaining Zero volt at output while sinking huge current.
Just see the output as a simple transistor that has a VCEsat or Mosfet with RDSon, you just can not sink lots of current while maintain the output voltage say at certain level that you want to, there must be a certain acceptable limit at certain current source or drain.
« Reply #6 on: April 18, 2013, 03:27:59 am »
i would not make the leap to call it a high precision power supply but its more precise than the LM324 ... i would pick up something more stable and longer lasting ... it can be socketed but would be a BITCH to get in to and replace
for this project we can offset the voltage on the output inner-software but for future reference thank you guys allot ... this might also explain troubles with my constant load ...
Online free_electron
    • SiliconValleyGarage
« Reply #7 on: April 18, 2013, 03:28:34 am »
when are people going to learn that there is no such thing as single rail or dual rail opamp.
An opamp has a pin to feed it electrons and a pin to return electrons. that's it. those are the two supply pins.
there is an input stage that works in a specified range referenced to these two supply pins.
there is an output stage that works in a specified range referenced to these two supply pins.
anything else you have ever been told about symmetrical and asymmetrical stuff is nonsense. it doesn't exist. it is an abstract concept and simplification of something that doesn't need any simplification.
Offline c4757p
  • adieu
« Reply #8 on: April 18, 2013, 03:33:55 am »
When the datasheet writers stop making blatant oversimplifications.
Offline BravoV
  • +++ ATH1
« Reply #9 on: April 18, 2013, 03:37:15 am »
...<snip>...
..aka... marketing jargon, nothing else.
If I'm not mistaken, the term "Rail to Rail" in op-amp's world is also copyrighted isn't it ?  ::)
« Reply #10 on: April 18, 2013, 03:48:07 am »
does it grind anyone elses gears when a data sheet writer puts stuff like "ultra accurate!" "best in class" and "NanoSpeed technology (r) (tm) (c) (u)"
like who the hell do they think there marketing to?!
"well i was going to go for the part with the specs i want ... BUT THIS ONE HAS NANOSPEED!" XP
also a side note i think single rail op amps are different than +/- rail ones
tho i know several dual rail opamps that work well with single rails ... like a TL082
Offline c4757p
  • adieu
« Reply #11 on: April 18, 2013, 03:52:41 am »
Any op amp will work on a single rail system; as f_e said, there's really no difference. "Single rail" op amps usually can reach closer to the negative rail. I would never describe a TL082 as working well on a single rail - the overhead it requires around both rails is quite large.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #12 on: April 18, 2013, 01:46:20 pm »
if you search harder, you can find thread where our teks engineer revealed the reason why single or dual opamp terminology emerged, its much to do with historical reason. and no, its not oversimplification. its making a simple thing "complicated". a simple thing by nature, but complicated to convey to people's mind, what they did is try to simplify the explanation but in effect making the nature looks complicated.
« Reply #13 on: April 18, 2013, 02:42:52 pm »
@biozz : hahaa. Good one. Reminds me of bob peases fast and damn fast opamps. He actually got that datasheet published in a databook..
Opamps are simple things. No need to make things complicated.
