Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Request for feedback on LED PWM driver output circuitry (Part 2)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Request for feedback on LED PWM driver output circuitry (Part 2) (Read 394 times)
daviegravee
Newbie
Country:
on:
October 18, 2024, 08:36:24 am »
I am looking for feedback, thoughts and general input on a design I am working on. This is a follow up to my previous post:
https://www.eevblog.com/forum/projects/request-for-feedback-on-led-pwm-driver-output-circuitry/
Key changes since the last post:
Cabling inductance and capacitance has been modelled as per one user's suggestion
Flyback diodes have been added to prevent ringing at the output (D1 and D2 in the simulation file)
Output filtering capacitor has been added
Ferrite beads have been added
Gate driver IC has been added. The design will actually use the UC27444, however there is no SPICE model available for this part afaik.
MOV has been added to the output, part not spec'd yet but will probably be the Bourns ZV60K1206121NIR1
I have attached a screenshot of my LTSPICE file that simulates one single output stage. There will be 24 of these in total.
The key points of the current design are:
PWM, constant voltage driver;
Each channel must be able to handle a maximum 4A, at 48V (24V will be more common in practice);
The design is not rated for 24 x 4A simultaneous drive, it's just that any channel used in isolation must be able to handle switching 4A at 48V;
Needs to operate in ambient environments of up to 55C;
Switching MOSFET is the DMNH6021SPDQ :
https://www.diodes.com/assets/Datasheets/DMNH6021SPDQ.pdf;
(however might be swapped to the IPG20N10S436AATMA1)
Minimum switching frequency will be in the range 200-400Hz;
Maximum switching frequency will be in the range of 15-20kHz;
The only heatsinking method that will be used in this design is copper of the PCB (see page 2 of the datasheet for thermal characteristics). I’m not up to layout yet, but I will be using the 2oz copper, 1-inch square copper plate to achieve a Junction to Ambient thermal resistance of 54C/W;
Thank you in advance!
Last Edit: October 21, 2024, 02:04:56 am by daviegravee
Logged
daviegravee
Newbie
Country:
Re: Request for feedback on LED PWM driver output circuitry (Part 2)
Reply #1 on:
October 21, 2024, 01:30:49 am »
Ah, I didn't realise that LTSPICE wouldn't embed the custom symbol. Here it is (in the .zip, the .asy extension is not allowed by eevblog...)
I've also attached a simulation without the gate driver in it.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
