Author Topic: Locating Shorts on Power Planes of Multi-Layer PCBs  (Read 2182 times)
Offline marshallhTopic starter
    • retroactive
Verilog tips
BGA soldering intro
Offline Artlav
  • Country: mon
    • Orbital Designs
Re: Locating Shorts on Power Planes of Multi-Layer PCBs
« Reply #1 on: August 12, 2014, 05:26:53 am »
Neat.
I thought it would be something about a thermal camera with a macro lens, while i was reading it. Dunno what gave me that impression.
Offline pickle9000
« Reply #2 on: August 12, 2014, 05:30:17 am »
that is cool.
Offline Richard Head
« Reply #3 on: August 12, 2014, 06:17:16 am »
Interesting approach. I expect a thermal camera would locate the fault very quickly.
Just the other day I was using a large electrolytic cap to blow open shorts on a two layer board. Plenty of microscopic shorts to the ground plane, The 0.2mm gap is a bit too small. The cap method is very effective for small shorts that a 3A PSU cannot blow open.
From now on I have opted for bare board testing at the PC board manufacturer.
Dick
Offline Bukurat
« Reply #4 on: August 12, 2014, 08:22:11 am »
Interesting
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #5 on: August 12, 2014, 08:54:26 am »
You could probably do it with an audio power amp and a microphone amp.
But a thermal imager is quicker! 8)
Day Job: Mostly LEDs
