Author Topic: Solar Cell to usable USB 5V, 1A project  (Read 5588 times)
Offline ninjastrikeTopic starter
« on: August 09, 2014, 08:25:23 pm »
Hello all,
I've been trying to figure out how to power a portable device using solar cells(via standard USB).
Since im producting 1.0 - 1.1V and about 8.5A, i'm thinking of using the Texas Instruments TPS61202 to convert this 8.5A and 1.0 V to a usable 5v and
the Texas Instruments TPS2513A-Q1 to be able to drive my USB charger.
Could anyone tell me if i'm going in the right track?
http://www.ti.com/product/tps61202
http://www.ti.com/product/tps2513a-q1
Cheers!
Offline Psi
Re: Solar Cell to usable USB 5V, 1A project
« Reply #1 on: August 09, 2014, 09:54:07 pm »
i imagine 1.0V cells are intended to be connected in series rather than used by themselves.
Boost converting 1.0V up to 5V is never going to be very efficient.
Have a look at the input voltage vs output current graph in the datasheet for TPS61202.
With 1.0V input the maximum output current is under 200mA.
« Last Edit: August 09, 2014, 10:00:41 pm by Psi »
« Reply #2 on: August 10, 2014, 10:46:18 am »
Hey PSI, yea that's true. What do you think the most efficient way to convert this energy?
Offline wiss
« Reply #3 on: August 10, 2014, 01:01:27 pm »
What is your reason to not have several solar-cells in series?
« Reply #4 on: August 10, 2014, 02:35:14 pm »
I want to be able to use it when i'm out say for a camping trip. So size is a design constraint.
Specifications :
Monocrystalline photovoltaic cell
6" x 6"
4.4W @ (STC): 1 000 W/m2, 25 °C
0.55V / 8A
Based on these specs, I would at most be connecting two cells in series.
Offline wiss
« Reply #5 on: August 10, 2014, 04:25:06 pm »
Unless you already have the cells I would go with something like this (not very cheap...)
http://se.farnell.com/bp-solar/msx-01f/solar-panel-1-2w/dp/654012
While googleing I also found this:
http://www.kjell.com/sortiment/el/batteriladdare/mobilladdare/apple/powerpack-1900-mah-p42041
about 10 USD, 20h of charging-time is hardly impressive and supposedly only iphone/ipad but considering the prise...
Offline mij59
« Reply #6 on: August 10, 2014, 04:42:51 pm »
Hello all,
Cheers!
Sorry, the same problem as with the LTC3105, can't handle high input current, as mentioned in the previous thread.
« Reply #7 on: August 11, 2014, 02:09:30 pm »
Hello all,
Cheers!
Are there some sort of current limiters which will be able to either disappate the energy that can be placed in the circuit?
« Reply #8 on: August 11, 2014, 02:10:31 pm »
I've got 10 cells lying around, I want to build it and enjoy the whole process.
Offline KedasProbe
« Last Edit: August 11, 2014, 02:28:42 pm by KedasProbe »
Not everything that counts can be measured. Not everything that can be measured counts.
[W. Bruce Cameron]
Offline mij59
« Reply #10 on: August 11, 2014, 02:33:56 pm »
Hello all,
Cheers!
You don't want to waste energy, there's already not much to work with.
Even assuming 100% conversion efficiency, 5V 1A at the output,  means at 1V an input current of 5A.
Offline wiss
« Reply #11 on: August 12, 2014, 10:21:40 am »
