I would need some more detail (specific settings for plotting, etc) in order to try to diagnose the problem.
@Marmad , and anyone else , who is willing to varify this RUU connection problem.
These are the conditions:
DS2072,
FW=00.02.01.00.03
HW 1
No options
PC w/Windows XP running RUU 2.03
Connected via USB
Now I recorded frames using the record button on the DS2072
I then like to select the start and end frame numbers by playing the frames using the Big Navigation knob. Once I know start and end frames, I use RUU to play my select frames
(connected via USB)
Edit: The error also occurs if the record was initiated by RUU
I then save the frames to a Frame array File ( see 1st Pix)
RUU running through the frames and the DSO shows each frame on the DSO display as the RUU program is saving the data.
After the saving of data is completed, RUU displays the 3D array ( see 1st Pix)
All the data in the Array is only the first Frame , repeated for all frames
Note. As RUU was requesting the data, the DSO was displaying the different frames
Note each frame in this test were displays of a frequency sweep.
Note that during the data transfer from the DSO to RUU , the UTIL -Record - Play menu was open on the right side of the DSO Display (See 2nd Pix )
Now if the 'UTIL' Menu is closed the RUU will save the correct frames (See 3rd Pix)
The Correct data is saved when just the 'UTIL' menu is open (see 4th Pix)
There is no error if the 'UTIL - PLAYBACK' Menu second Page is Open (See 5th Pix)
The same bug exists on FW 00.01.01.00.02
I hope this helps.
