So I'm curious if anyone else has seen any quirky behavior with the DS2000 when the LAN mode is used with Ultra Sigma or RUU.
Well I have been having problems with RUU compling frame files.
The playing of recorded Frames appears OK
But!
I only get 1 frame, at one setup (FW 2.01.00.03)
and later
I only get a Blank 3-D gird.,
The saving of the FrArray steps through the Frames on the DSO , OK
but no frames get to the small RUU file
I have managed to clear the lock up by playing with I/O set and LAN settings
not sure witch, but change a reboot, change and re boot DSO .
somehow something gets reset
and now RUU is OK at latest setup.
Displays below show 1 stuck plot then 2 good Frame Compile 3-D plots
