Evi, let me know your OS version, and whether 32-bit or 64-bit and I'll sort it out, test, and re-post.
Windows 7/32
Ultra Sigma and RUU works fine.
Hi Evi, try the updated version, let me know how you get on? Have tested this on Windows 7 x32. No need to copy any files, as long as NI-VISA 5.2 or 5.3 is installed. If it doesn't work, again, could you let me know which NI-VISA you have?
/forum/projects/software-tips-and-tricks-for-rigol-ds200040006000-ultravision-dsos/msg261360/#msg261360
Hello, it's getting better... But why
USB INSTR ?c: \ Program Files \ RIGOL Technologies, Inc \ Scope Commander> scopecommander
Devices found: 2
Device: ASRL3 :: INSTR
* IDN?
An unhandled exception: System.ArgumentException: An invalid resource type wa
s passed into the resourceName parameter. The resource name is valid for your s
ystem, but it is not of type USB INSTR. Either provide a resource name with the
correct resource type, or set the checkResourceType parameter to false.
Parameter name: resourceName
in NationalInstruments.VisaNS.Session .. ctor (String resourceName, AccessModes a
ccessMode, Int32 openTimeout, String expectedResourceName)
in NationalInstruments.VisaNS.MessageBasedSession .. ctor (String resourceName, A
ccessModes accessMode, Int32 openTimeout, String expectedResourceName)
in NationalInstruments.VisaNS.UsbSession .. ctor (String resourceName)
in NS.VisaNetDriver.query (String connString, ConnectionType connType, String t
ext) in C: \ Users \ nathan \ Desktop \ ScopeCommander Com \ VisaNetDriver \ VisaNetDriver.vb
: line 46
in NS.Scope.Module1.Main () in C: \ Users \ nathan \ Desktop \ ScopeCommander Com \ ScopeC
ommander \ Module1.vb: line 31
