DS2072 FW1.00.02 RUU 1.5
A small quirk,
With RUU , after recording frames, then playing them back in Repeat Mode, the repeat mode check box is allowed to be unchecked but the DS2072 will not allow it to be changed, So the RUU shows no "Repeat" mode but the DSO is running in 'Repeat mode'.
If the RUU play is "Paused" then the check box is updated to show still in Repeat Mode,
I guess there is a couple of ways to address this:
1: don't allow "Repeat" Box to be unchecked, if playing
2: stop the Play and unchecked the "Repeat" box and set the DSO to no 'Repeat'
3: state "That is the way it is"
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
