Author Topic: testing LM324 OP-AMP  (Read 4642 times)
Offline hussamaldeanTopic starter
  • Country: iq
« on: March 17, 2018, 05:35:44 pm »
I want to build PWM generator circuit using this op-amp. however, I start to doubt that the op-amp is not working since it doesn't draw any current from my PSU
is there any way to test if it does work ?
Regards
Offline Brutte
Re: testing LM324 OP-AMP
« Reply #1 on: March 17, 2018, 05:47:27 pm »
If it does not draw any current (i<1pA) then there is no need to investigate that part further.
Idling device should draw idle current, more or less.
Offline precaud
    • LinearZ
« Reply #2 on: March 17, 2018, 05:49:31 pm »
: Double-check your supply voltages.
: Short pin 1 to pin 2
: Put a 1kHz signal into pin 3
: Measure at pin 1, should be the same as the input at pin 3.
  • Country: iq
« Reply #3 on: March 17, 2018, 06:22:32 pm »
I'll test it soon
I can't be 100% sure since my psu has 10mA resolution only (Uni-t UTP3315TFL)
so basically I can't be 100% sure
Offline Zero999
  • 0999
« Reply #4 on: March 17, 2018, 06:51:06 pm »
Post the schematic.
The LM324 seems to be a poor choice for a PWM circuit, because it's very slow.
  • Country: iq
« Reply #5 on: March 17, 2018, 07:05:47 pm »
Post the schematic.
Offline Zero999
  • 0999
« Reply #6 on: March 17, 2018, 07:18:33 pm »
Post the schematic.
The LM324 is no good for that circuit. Use a comparator IC with a push-pull output, such as the LMC6762 or TLC3702. Alternatively, the LM393 or LM339 will work with 1k pull-up resistors to 5V.
You'll need to make sure the MOSFET can pass the required current, with a gate voltage of 5V. Consider powering the PWM circuit off 9V, directly from 12V or using a MOSFET driver IC.
What's the maximum expected supply voltage? Will this be run off a car's electrical system? It may be necessary to add some overvoltage protection circuitry
  • Country: iq
« Reply #7 on: March 18, 2018, 04:18:13 am »
Post the schematic.
the circuit for reference, I will use L298D motor driver though
