Author Topic: 5V DC to +/- 15V DC  (Read 4835 times)
Offline cncjerryTopic starter
5V DC to +/- 15V DC
« on: August 29, 2018, 05:01:40 pm »
I need a DC to DC converter made from discrete components.  I had been using a monolithic converter but I keep popping them and until I get the 15V opamp circuit under control, I would like to use cheap devices.  I only need 50 to 100ma out of the +/- 15V.  I looked around and see some high voltage circuits but not something in this range.
Thanks
Jerry
Online T3sl4co1l
    • Seven Transistor Labs
Re: 5V DC to +/- 15V DC
« Reply #1 on: August 29, 2018, 05:22:47 pm »
Why not buy one that's current limited?
Seven Transistor Labs, LLC
Online SiliconWizard
« Reply #2 on: August 29, 2018, 05:40:50 pm »
You could use some kind of isolated DC/DC converter such as the Murata NDTD0515C: https://power.murata.com/en/ndtd0515c.html . It has short-circuit protection. About 15 bucks and it just works.
Don't know whether isolated could be a problem in your case or not, but those Murata are sturdy parts.
Online Benta
« Reply #3 on: August 29, 2018, 06:20:48 pm »
Use a Traco Power module for prototyping your opamp circuit. After that, you have time to spin your own.
« Reply #4 on: August 30, 2018, 04:19:37 am »
I was trying to keep the cost low as I've blown those converters up a couple of times.  I figured if I could build one with a couple of transistors I could pop them in when needed.
Thanks
Offline Buriedcode
« Reply #5 on: August 30, 2018, 04:32:25 am »
At >50mA charge pumps are pretty much out so you're left with either a boost or push-pull with custom magnetics or an off-the-shelf module with built in current limiting as suggested.  What volume are we talking here?  If it's really that cost sensitive you could just go with a cheap(ish) converter and add your own current limiting.
Online Wolfgang
    • Electronic Projects for Fun
« Reply #6 on: August 30, 2018, 07:31:37 am »
I made one myself to power a low noise amp from USB. Look here:
https://electronicprojectsforfun.wordpress.com/power-supplies/a-usb-powered-15v-supply/
Its quite some circuitry, but results are OK.
Offline Zero999
  • 0999
« Reply #7 on: August 30, 2018, 10:14:44 am »
Thanks
Getting a current limited DC:DC converter will not fix the problem. Figure out why the 5V to +/-15V converter is failing first.
Online T3sl4co1l
« Reply #8 on: August 30, 2018, 10:38:15 am »
Thanks
Um?  That's basically the cause and solution in two sentences. ;)
FYI, if a DC-DC converter doesn't specifically say it's current limited or short protected, it will release the magic smoke if you try.  They're usually a two-transistor chopper configuration, no control, no regulation, no limiting at all.
Particularly common in the very small ones, that can't afford any room (or budget) for those functions.
Offline Zero999
  • 0999
« Reply #9 on: August 30, 2018, 12:49:11 pm »
Thanks
Whoops. I meant to say figure out why the device the DC to DC converter is powering, is drawing too much current and causing it to fail. Replacing the DC:DC converter with a current limited one will not solve the problem. The device it's powering will just cause it to shut down or current limit and it still won't work. Fair enough, it offers the ability to do some debugging, but it will not solve the problem.
I'd advise building/buying a +/-15V current limited power supply supply. It's easy to make one with a 15-0-15V transformer, a bridge rectifier, some big capacitors and the LM78L15 and LM79L15. Note I suggest the L versions to limit the current to <200mA and they're cheap too. Now the circuit can be debugged and put back into the original system, once it's working.
Online T3sl4co1l
« Reply #10 on: August 30, 2018, 01:18:32 pm »
Ah right, that makes more sense :)
I assumed the problem was clumsy probes and debugging, so the problem will be solved in due time (heh, hopefully?).  If this were a replacement sort of thing for example, yeah, something else is broke, yo.
Online Ian.M
« Reply #11 on: August 30, 2018, 02:17:56 pm »
An add-in 100mA current limiter for debugging could be quite simple - use the classic OPAMP + N-MOSFET constant current sink circuit for the -15V rail, and its P-MOSFET mirror as a constant current source for the +15V rail, All its going to need is a dual rail to rail OPAMP, the MOSFETs on a small heatsink, a couple of Zeners for Vgs clamping and a few passives.
It will spend most of its time with the OPAMP outputs stuck at opposite rails as it tries to turn the MOSFETs on harder to increase the current, but when you hit the limit, after a very short surge while the OPAMP output unsticks from the rail and starts slewing hard towards the MOSFET Vgs threshold voltage it will cut the current back to its limit.   Foldback limiting could be added with an extra resistor from each OPAMP output to its control voltage (in+) input (from a resistor divider between the rail and ground) to cut back the commanded current once the output has unstuck from the rail, sized so it never takes the commanded current below say 10mA.
Even some 50mA polyfuses, + clamping diodes so you cant drag the + rail below ground or + rail above ground would probably save your day.
« Last Edit: August 30, 2018, 02:32:51 pm by Ian.M »
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #12 on: August 30, 2018, 02:24:07 pm »
I used LTC LT3439 for isolated DC-DC for exactly those voltages, was very happy with low noise and easy design. Also uses off-shelf transformer, no need DIY stuff.
Crude prototype board, showing regulator (on the right). Just 9 parts in BOM:
What makes you think that discrete regulator would be less poppable?  ;)
Offline DaJMasta
    • medpants.com
« Reply #14 on: August 30, 2018, 02:48:03 pm »
There's also the option of wiring in a lab power supply and when it works, you have an easy way to readout your current requirements and pick an appropriate module.
Online Ian.M
« Reply #15 on: August 30, 2018, 03:12:57 pm »
Yep, and if power sequencing is an issue, but not excessively critical, simply run the lab PSU feeds through a DPST relay with its coil driven by the 5V rail, with schottky clamping diodes from the output rails to 0V so none can cross 0V due to slight differences in the relay contact open or close times.
« Reply #16 on: August 31, 2018, 01:46:46 am »
Just in case
https://www.ebay.com/itm/5V-6V-9V-12V-15V-24V-Positive-Negative-Dual-Output-power-supply-DC-DC-Step-up/183250767422?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
How did you know I bought a half dozen of these?
The +/- 15V is for a curve tracer I am redesigning based on one published in QST two years ago.  I have Parkinsons so I shake and probing has become difficult. The unit I've been using is  a Murata MEA1D0509DC.  They are 5.45 per and I need two for +/- 18v though +/- 15 works as well.  I have two Universal Micro units that are large and work fine but I don't want to blow these.  They are pricey and purchased for another project.  I've blown three of the Murata units already and to this day I don't now why, they are on a breadboard and they just stop working and I'm out 5 bucks.  I am using the Universal units now and I was thinking of building the curve tracer into a TM5000 unit which would solve the power problem.  But in the meantime, I was thinking of building my own converter if I could find a circuit.  That way if I pop a small signal transistor it's no big deal.
Anyway, thanks for the input.
Jerry
