We do have a generator but it is a god awful noisy thing. The new solar system is to try and replace some of the local grid usage as it is frightfully expensive.
Further to my solar system design there are a few questions or design issues that I need help with.
My original design thoughts were fairly simple or so I thought.
1) Solar DC output panels on the roof.
Feeding a battery charge controller to the batteries.
2) Inverter converting DC from the batteries to 120 VAC for use by the freezer.
And then I began hearing lots of suggestions which seem like really good ideas though I have no clue as to how to fit them into my simple design.
1) Apparently the solar panels can now produce AC, so would that mean that I would need 2 inverters.
2) I read where it is a good idea to have a device to be able to balance the charges on the batteries. Where does that fit into my simple design,
3) And more reading said that there is a battery charge controller/inverter that could simultaneously charge the battery and power AC devices
Is there such a critter ?
The mind reels.😳😳
