By looking at all 3 spectrum measurements, what intrigues me is the fact that in the last one, 2
nd, 3
rd and 4
th harmonics are about the same value, -70dBc.
In the first measurement there are big differences between the level of them, but with the next measurements, when the level of the fundamental is lower, all the harmonics tend to become equal.
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Now, as explained in
https://wiki.analog.com/university/courses/electronics/comms-lab-peltz-osc
the amplitude on the LC tank is limited by the forward voltage drop on the BC junction of each transistor. One transistor for each polarity of the oscillations, which means, if the two transistors have a different V
BC forward drop, then the generated sinusoid will be asymmetric in respect to X axis (in time domain), which means (in frequency domain) even order harmonics.
Also, the two V
BC junctions will limit the amplitude, turning the sinus into a more square"-ish" waveform. This type of distorting will translate into odd order harmonics. I don't know what leads to equal odd and even harmonics, maybe it's just a coincidence, though it doesn't look so to me, it looks like the lower the oscillation, the more equal harmonics.
First things I would like to experiment with would be:
- to try well paired transistor (for identical V
BC, thus symmetrical waveform, thus less even harmonics)
- try to put the output signal through an exponential amplifier. The idea is to try to reverse (in time domain) the amplitude limitation/distortion introduced by the forward biased BC junctions by applying to the output signal the inverse function that produced the distortion. The hope is to get lower distortions/harmonics.
About the optical gyros (I know nothing about the implementation details, only the principles), I wonder if using total reflection would have lowered the backskattering. I imagine getting very flat glass surface would be easy by simply letting the melted glass to cool. Using longer wavelength for the light, so the wavelength will be big in relation to the ruggedness of the glass surface, should help too. But I guess these were considered already.
Were those gyro mirrors made out of glass, or metal?
