Author Topic: SIMPLE power supply  (Read 10104 times)
Offline ICSB_TechTopic starter
SIMPLE power supply
« on: April 01, 2012, 08:51:27 pm »
All this talk about power supplies and such have inspired me to go get/make one myself. I've been looking around for a simpler design but I'm not really sure what to look for. Usually I work with audio stuff, mostly effects pedals (usually 9V) and microcontrollers.
Maybe you'd have some advice for a simple linear power supply, here's the specs I'm looking for
  • Voltage up to 9v (maybe 12V, but that's not completely necessary)
  • Doesn't need to be highly adjustable, just like have a 3.3V, 5V, and 9V settings
  • maybe current limiting? (I'm not really sure how to do this part, I understand the voltage, but not sure how to limit current)
  • Powered by a wall wort, 9V or so (I live in Europe, and I'm moving back to America in a few months, so I don't want something with a transformer)
Advice on what parts to use, or maybe even a schematic would be awesome!
Offline cyberfish
Re: SIMPLE power supply
« Reply #1 on: April 02, 2012, 03:24:54 am »
Adjustable current limiting would be the hard part.
Otherwise you can just use a LM7809, LM7805, and a 3.3V linear reg.
It also depends on what kind of current you need.
Offline TriodeTiger
« Reply #2 on: April 02, 2012, 04:21:40 am »
Something like two LM317's would look like something you can do. It's a common item in DIY power supplies.
Voltage adjustment:
You can replace the voltage pot (R2 in next figure, which works as in a voltage divider configuration) with a selector switch and appropriate resistor values for 3V3/5V/... if you do not wish for more adjustable voltages.
The formula means more or less "Vout = Vadj + Vref", meaning the range will be from 1.25V (Vref) to (Vin-Vdrop). You should get up to near 10V out on a 12V plugpack. If you want 0V, you can offset with -1.25V, although with added complexity.
Current limiting:
The current pot (R1 in next figure) can be replaced with a power resistor to keep the limit to say 500mA. Resistor must be able to dissipate I^2*R watts as it is in series with the load. Current limiter will drop some voltage, so it should go before voltage reg. You may get 1.25->9V with it added, however that is fairly good for its simplicity.
LM317 can go up to 1.5A if I recall with heatsinking. LM350 to 3A. Not sure what your current requirements were. :)
http://www.digikey.ca/product-detail/en/LM317T/LM317TFS-ND/458678 @ $0.71 each
« Last Edit: April 02, 2012, 04:38:32 am by Alexander »
"Yes, I have deliberately traded off robustness for the sake of having knobs." - Dave Jones.
Offline BravoV
  • +++ ATH1
« Reply #3 on: April 02, 2012, 04:25:24 am »
If you want simple regulator yet have current limiter, look for L200 ic.
Offline TriodeTiger
« Reply #4 on: April 02, 2012, 05:14:52 am »
Not a bad part! I'd say the 2.85V minimum voltage output is a little high, but fine for the 3V3 he asked. It's only $2 too.
Offline BravoV
  • +++ ATH1
« Reply #5 on: April 02, 2012, 05:31:28 am »
Exactly, quite cheap, pretty easy to build and almost indestructible and fool proof even used by a noob.
Offline Jeff1946
« Reply #6 on: April 03, 2012, 12:13:07 am »
Agree with others, you might use power supply from an old laptop as a DC voltage source to power the regulators discussed by others.  Most will work on 100-240 volts.  Hopefully you can get one for free from someone with a dead laptop.
Offline Monkeh
« Reply #7 on: April 03, 2012, 02:29:59 am »
Indeed, that's going to be the basis of a supply I'm putting together shortly. It's often easy to find them with damaged cables or connectors which you can repair or replace easily, I have one with the connector falling off.
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #8 on: April 03, 2012, 12:53:42 pm »
As there are many well known approaches to a making a simple stable linear supply, for decades they have sold these as kits.  It will save you a lot of time and energy, just check Amazon.com or others.  The key is understanding how the parts are used as you assemble them:
http://www.amazon.com/Velleman-1-5V-35V-Power-Supply-Kit/dp/B0002Z82PS/ref=sr_1_1?ie=UTF8&qid=1333457301&sr=8-1
http://www.amazon.com/Elenco-0-15V-Power-Supply-Kit/dp/B0002DVF4K/ref=sr_1_1?ie=UTF8&qid=1333457271&sr=8-1
« Last Edit: April 03, 2012, 12:59:24 pm by saturation »
Best Wishes,
 Saturation
Offline sorin
Offline T4P
  • Country: sg
    • T4P
« Reply #10 on: April 03, 2012, 10:45:21 pm »
A simple power supply consists of a 7805 with a 10C/W heatsink off a 6VAC tap (rectified 7.1V)
7812 with a 10C/W heatsink off a 12VAC tap (rectified 14.9V)
For higher currents Or you can simply use the LM323 or the LM2576
And you can also use LM723 switching a transistor to get 0-37V instead of the LM317
http://www.bristolwatch.com/ele/lm317.htm
But really if you don't want to spend much money on heatsinks , get switching ones if you want high current capability .
