So I’ve been doing some more research on this. The seperate cells/modules have passed the required tests. If I can verify that my assembly cannot overcharge, short circuit, or over discharge the batteries then everything should be fine with the original 38.3. If I can’t verify that then the new assembly would need re tested under 38.3.3.1.
Any experts on the matter?
