First of all I'm aware that single phase motors need full sine wave to make the pulsating field, so let's assume that i don't include them in my talk.
I'm designing a sine wave inverter with push pull topolgy and I thought: why do we have to design the inverters with the full (+ and -) swing?
Many loads don't care about positive or negative swing, they rectify it anyway
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
Why would I want do that? well.. becuase ,comparing with push-pull, we need only one mosfet to operate the device and we don't need a center tap so we can use the full winding of the primary coil and get double the power we got before (less cost and higher power).
So what stops me from doing that? (I need to power a switched mode power supply , tv ,and a couple of leds and i don't think any of them care about the full swing)
( If my question is too naive, you can move it the the beginner section
![Undecided :-\](https://www.eevblog.com/forum/Smileys/default/undecided.gif)
