Ok, I managed to simulate it!
I use TL072 as for LM358 Proteus has no simulation model.
I 've also replaced D45H11(Q2) with a BD912 because D45H11 has no simulation model.
I power it with a voltage source, 30V.
I put the CV Pot in the middle, CC Pot on the top (max current).
These are the results:
RL=30 Ohm, 0.47A, 14.2V
RL=25 Ohm, 0.57A, 14.2V
RL=20 Ohm, 0.71A, 14.2V
RL=15 Ohm, 0.94A, 14.2V
RL=10 Ohm, 1.40A, 14.0V
RL=5 Ohm, 1.56A 7.8V
Conclusion: It cannot give enough current.
I have uploaded in .pdf (change it to .pdsprj) and in zip format.
