Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
How to run a galvanometer?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: How to run a galvanometer? (Read 1898 times)
somlioy
Regular Contributor
Country:
on:
May 22, 2013, 07:41:18 pm »
I got one of
these
insulation monitors at work, and I want to replace the electronics in it with some custom stuff for another application. But I'm not quite sure how to drive the galvanometer , does anyone have a clue? Resistance measurements shows about 60ohms when the pointer is held still. Jumping up if moving.
Last Edit: May 24, 2013, 12:35:46 pm by somlioy
Logged
qno
Frequent Contributor
Country:
Re: How to run the analog pointer indicator
Reply #1 on:
May 22, 2013, 08:45:22 pm »
Usually they are controlled with current anywhere in the 0 to 100 uA range to 0-10 mA.
Ad a current meter in series and you can measure the full deflection current.
Its a galvanometer (wiki ) a coil that rotates in a magnetic field.
Logged
Why spend money I don't have on things I don't need to impress people I don't like?
somlioy
Regular Contributor
Country:
Reply #2 on:
May 23, 2013, 01:32:34 pm »
So thats what they're called. Easier to get some results ongoogle then.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
