Hey all,
Just trying to finish off a 'portable' microcontroller rig, and I'd like to go super simple with the
power supply on this, and more importantly get the components in order.
So, I have a 12v 7.2 aH SLA battery, SLA charger and various boards I need to power (including
a Futurlec Atmega128 board, which BTW has a weird negative center DC connector, but standard
7805 reg. The other power is for a UBEC reg (for RC model servos).
What I'm asking in a roundabout way is what the minimum requirements are for a circuit, and in which order components are placed.
This circuit should have fusing and polarity protection and maybe also DC voltage smoothing.
So, first off I thought I'd remove the DC connector from the Futurlec board as I don't have any male connectors to fit this (the inner pin is too big for a start, let alone negative voltage).
Having the MCU board sorted I then need to handle the battery and charging inputs.
The SLA charger I bought from Altronics has female spade terminals. No biggy there though...
Anyway, just playing around with Eagle I thought the following might be the order of things,
(maybe attached) but as usual, I'm probably wrong.
Any thoughts on this guys?
